Old 11-29-2014, 01:14 AM
Default Re: Liebherr 944B
I use 4s 5000, easy digging is over an hour, hard digging about 40-50 minutes.
The latest models from Fumotec have rubber feet about 8mm tall. If nothing else shorter available, I'm sure you could cut out a square piece of rubber from tractor tire tube, the type that are filled with chloride as they much thicker than a car tire tube. But maybe a car tire tube would be enough.
Rubber fuel line is quick and easy, I used it on my pickup's little air compressor.
Cheers, Neil.
