Old 12-28-2014, 01:56 AM
Barker196 Barker196 is offline
Barker196 is on a distinguished road
Default Re: 4 Hour Bruder Dozer
I love the diesel soot! Your craftsmanship amazes me!
Old 01-02-2015, 05:51 PM
*tonto* *tonto* is offline
*tonto* is on a distinguished road
After reading this entire build thread like 20 times, the craftsmanship and detail you put into these machines just blows my mind. I could watch your builds for hours, and I would still not have seen enough. You have inspired me to build my first Bruder dozer. I noticed that you had a carton of the metal track pads in one picture. Just wondering if they were just put in there, or were modified pieces of some sort? Also on #2 it looks like you used a different method of attaching the pads to the chain drive. I would like to use your ideas for my own build and any help would be greatly appreciated.
Once again well done, and thank you for your builds.
*TONTO*
Old 01-03-2015, 12:08 AM
*TONTO*
Thanks tonto and welcome to the forum. I see you are in Vancouver. Perhaps we will see you at one of our shows on the island this year? The track pads are made from trim that you can buy at Home Depot or Rona. It comes in 8' lengths so you will need to cut it to the size needed and drill the holes for mounting. The chain used on dozer #2 is #35(3/8 pitch) with K1 attachment on every other link. If you have any other questions fire away. Good luck with the conversion should you take it on!
Reg
Old 01-03-2015, 12:48 AM
Thanks for the info. I just picked up a dozer from Winners, and will definitely be trying to do a chain conversion. I live in Abby, I just like to put in Vancouver just so people know the general area I live in. As for shows, how do you find out if there is going to be a setup for R/C's there? At the end of January there is an agricultural show at the tradex, I just don't know who to get into contact with.
Old 01-04-2015, 10:58 AM
Rvjimd's Avatar
Rvjimd Rvjimd is offline
Reg,
Do you have a part number or measurement on the edging material for the track pads so I can make sure I get the right stuff?
And, I don't think I understand the slot in each pad? It sort of looks like it could be used to drive the tracks from the sprocket, but that is being done with the #35 chain right? Is the slot for looks or something else I do understand?
Jim
Old 01-04-2015, 11:24 AM
Originally Posted by Rvjimd View Post
Reg,
Jim
It's called 7/8 grooved edging(Rona part# DUA101MLU08). I have been talking back and forth with someone else in the US about finding some for them. It almost seems as though only Canadian stores carry it which seems odd. The slots in the track pads are to let dirt out. Without them I found that dirt packs up in the links and won't come out. Milling the slots almost doubles the time it takes to make the pads but I like the look of it and at least some of the dirt escapes.
