Old 12-31-2014, 10:44 AM
Dieselchopper's Avatar
Default Re: MorePower Hydraulic
I have been dealing with more power for over a year. The pump is strong, be cautious with your pressures as I have split lines. The nipples are weak at the transition point from m3 to instillation nut. Have broken many. They are good at replacing things if you ask. I am a Canadian dealer for them. But most cases it is still cheaper to deal direct as I get no different deal at this time. I will be running their system in most all of my future builds. Happy building!
Old 12-31-2014, 02:38 PM
rc_farmer's Avatar
Master Builder
Chris, i don't kow the pressure yet, still need to get a gauge. I also ordered a PRV from rc4wd as i think the one that came with the excavator is bad. I talked to Steve yesterday....i disconnected everything from that PRV and could not blow any air thru it. The reed stem, which is cone-shape with a rod surrounded by a spring sticks so tight in the opening, i had to jam a screwdriver into the outlet to free it.....that what was causing the pressure to burst line when we did hook it up correct.
I have seen these pumps modified to accept brushless motors as well, i will figure that out
Oh yeah, they ship fast too. less than 10 days from order to doorstep
Giving up is not an option!!!
Rob
Old 12-31-2014, 02:55 PM
woodhog's Avatar
woodhog woodhog is offline
well at least you know what was wrong with the other system
Woodhog
