Old 12-31-2014, 07:52 PM
apfubar apfubar is offline
Default Re: Dx8 channel mixing help
Here is how I have my 966 setup:
- channel input config: pump channel - inh (removes it from any switch)
- Programmable mixes:
1. On > pump channel, rate: 100/100, offset 0, switch on (this sets zero to -100)
2. Source/input channel > pump channel, rate: -100/100, offset 0, trim inh, Switch on
(For each hydraulic valve you repeat point 2)...
I suspect the -100/100 though is the key.
Cheers,
Ap
Old 12-31-2014, 08:40 PM
justin justin is offline
justin is on a distinguished road
Cheers,
Ap
Thanku Andrew Ile try this over the wkend
Thanks again
Justin
