Old 01-03-2015, 06:18 PM
rc_farmer's Avatar
Master Builder
Default Re: MorePower Hydraulic
Success!, I think i have figured out the hydraulics. Here is a quick video of the setup. I would highly advise that anyone who has the Morpower block to pressures test all the fittins and replace all the 3mm set screws before installing in your machine. I have replaced 5 of them that was leaking with 3mm caphead screws.....no more leaks.
Giving up is not an option!!!
Rob
Old 01-03-2015, 06:21 PM
You're not running their pump though? RC4WD pump in that video?
Old 01-04-2015, 12:53 AM
rc_farmer's Avatar
Master Builder
That is a Morpower valve block. I bought that pump as an extra when i bought the setup. The original pump is a 540type brushed. I am going to replumb everything once in the excav. I am also going to use a different type tank.
Also, those servos are junk. The kill the rcv'r if more than two are plugged in, Steve said to use Hitec 85mg which i will p/u on monday.
Rob
Old 01-04-2015, 01:26 PM
I was just wondering if you used the RC4WD style pump because you didn't like the Morepower one or???? I almost ordered a pump from them a while back but chickened out. Just wondering what your thoughts were on it compared to the RC4WD pump? I would like to buy a pump for my log skidder and it needs a fair amount of volume.
