Old 01-04-2015, 07:45 PM
Default Re: 4 Hour Bruder Dozer
Originally Posted by Ben1272 View Post
That's great! I will order some and have it sent to my local home depot. I have been wanting to try this approach for years, ever since reading about Greg (RCLOGGER) using it on his equipment!
Thanks for posting your find! Now I can stop bothering Reg offline.
-Ben
Haha, you were no bother at all Ben. I hope this works out for you guys!
Reg
Old 01-08-2015, 08:51 PM
DieselKid's Avatar
DieselKid DieselKid is offline
DieselKid is on a distinguished road
These are so cool Reg!!! Love the ROPS cage!
-Alex
Whatever floats your boat, just as long as it doesn't sink mine...
Old 01-15-2015, 03:29 PM
Rvjimd's Avatar
Rvjimd Rvjimd is offline
FYI ...
I got my aluminum edging stock today. Looks like the rest of the free world can order grouser raw material!
Thanks Reg!
Jim
Old 01-15-2015, 08:21 PM
That's great Jim! I'm glad it all worked out.
Old 01-16-2015, 05:00 PM
Ben1272 Ben1272 is offline
Ben1272 is on a distinguished road
Reg, do you think plastic sprockets could hold up for use with the #35 roller chain based tracks? I can design and print them on my 3D printer in ABS plastic or PLA plastic, which is a bit harder than the ABS. Will sand, etc., just wear them away prematurely?
I think I am going to give it a shot and see. Can always convert to aluminum if it is a no go.
My aluminum extrusion is due here any day.
Thanks for your help,
Ben
Old 01-16-2015, 05:20 PM
I guess it depends on how much sand you are running in but I'm sure they will last a while. It's not like it's a really heavy model. You can always print more anyway right! I like the design! They look good. I need to get myself a printer that's for sure. What type do you have?
Old 01-16-2015, 05:26 PM
I have a solidoodle4. It is not bad for the $599 price tag! I have mine adjusted pretty nice right now and get pretty decent prints now. It definitely takes a little bit to learn about the machine and what it can do and how to design parts given its limitations. The parts being ABS allow solvent bonding so larger more complex parts can be broken down into smaller more manageable parts and then bonded together. The sprocket I showed was printed from two parts, designed to be keyed together, and then solvent bonded.
I am going to make the entire drivetrain with this approach and will post pictures as I get further along.
I think I am also goinf to use the printer to make a fixture to hold the extrusion while I mill the sides clean and drill holes and mill slot.....we'll see how that idea pans out!
