Old 01-07-2015, 04:18 PM
Supermario's Avatar
Your drive roller should be pulling the belt. Looks good, runs quiet & smooth.
I think you'll be hard pressed to get much more than 20° without too much rollback.
Originally Posted by andyathome View Post
nice conveyor, have you thought about gluing some teeth to the belt to allow you to have a higher incline if need be.
I found on mine (4 feet long)about 15 degrees was the max before the rocks started to roll down hill, also if I slowed it down you can go a little steeper.
cheers andy
Ouch! I'm not liking the numbers you guys are saying but I never doubt people who speak from experience. At those angles I'm going to need a lot more space to make this all work.
I was wondering if drive roller must be on the top end? The way it is now all the belt tension is on the bottom which allows the top to have slack and maintain that curve or cupping effect? I guess with heavy material trying to push up a loose belt won't work though..... Ok. Never mind
I like Lou's idea using the leading edge of a wiper blade as paddles or teeth on a belt. Just not sure how well they will adhere to the treadmill belt?
Currently Active Users Viewing This Thread: 64 (0 members and 64 guests)
