Old 11-28-2010, 12:11 AM
Default Re: Tamiya Semi - MAN Steering (Ackerman Steering Principle)
Albert, I'm curious to see some photos of the stock set-up and what you are running now. I am mainly interested to know what the difference is, in simply moving the steering link to the rear. Is it better because the inside wheel turns in more then the outside wheel, as it should be? The throw is still the same, right?
Old 11-28-2010, 12:30 AM
aseejr aseejr is offline
aseejr is on a distinguished road
Yes. It is because the inside wheel turns sharper than the outside wheel. Throws are the same before and after as I always max them on both sides using my travel adjust on my transmitter. Sorry I don't have before pictures.
Albert
