Should make a couple training rollers there a set of rollers on a pivot with upright side rollers. that helps center the conveyor. We use them on all our conveyors at work.
Yes I plan to add more rollers and a pair at each end that are more vertical. I scooped a picture of a setup I liked on the net that I believe has what you described but this was all in managed to get done in a few hours this afternoon. I was more interested to see if I could get something moving with pieces I had lying around before I spent more time on it. I think it will work for my needs whatever they are
OK, so I ditched the first conveyor in favor of what I had wanted to do in the first place. I've had a nasty cold the last few days so I decided to take it easy and use the long weekend to get started. This one is quite large at nearly 5 feet. The belt is 3 1/2" wide. The treadmill I used still worked but was slightly disassembled(controls were off). I thought it would have had a brushless motor but it turns out to have a 90v brushed motor instead. This worked out awesome as I was able to power it up with 12v and cut the strip off with a razor blade. I just held the blade steady and the treadmill did the work! What I have done so far is very basic. I have yet to make any rollers other than at the ends but it still runs pretty true. I have a ton of work to do on it yet so this will be an ongoing project.
http://youtu.be/eKVmfTlKWbA ![]() ![]() ![]() |
On going project you say?..... Tell me about it!
![]() The latest is looking great! And your getting ahead of me on this one! Must have something to do with the fact you have no winter! ![]() ![]() ![]() That's my story. ![]() |
Thanks RW. Feeling a little better today but not great. Perhaps some salt air tomorrow will fix me up!
I made up the hopper yesterday afternoon. Today I got to give it a quick test. I use a cordless drill trigger when I'm bench testing things and I was using it here. I had it pinched under the weight of the conveyor but it got knocked around stopping the belt a couple of times. I think it will work OK though with some more effort. I was concerned that the speed would be too slow but it actually looks pretty good. If it were any faster I couldn't feed it quickly enough...
http://youtu.be/vUvI5S-ZL34 ![]() ![]() ![]() |
Currently Active Users Viewing This Thread: 9 (0 members and 9 guests) | |
