Old 01-13-2015, 11:00 PM
Default Re: RCP Compound
Yes I plan to add more rollers and a pair at each end that are more vertical. I scooped a picture of a setup I liked on the net that I believe has what you described but this was all in managed to get done in a few hours this afternoon. I was more interested to see if I could get something moving with pieces I had lying around before I spent more time on it. I think it will work for my needs whatever they are.
Old 02-09-2015, 08:49 PM
OK, so I ditched the first conveyor in favor of what I had wanted to do in the first place. I've had a nasty cold the last few days so I decided to take it easy and use the long weekend to get started. This one is quite large at nearly 5 feet. The belt is 3 1/2" wide. The treadmill I used still worked but was slightly disassembled(controls were off). I thought it would have had a brushless motor but it turns out to have a 90v brushed motor instead. This worked out awesome as I was able to power it up with 12v and cut the strip off with a razor blade. I just held the blade steady and the treadmill did the work! What I have done so far is very basic. I have yet to make any rollers other than at the ends but it still runs pretty true. I have a ton of work to do on it yet so this will be an ongoing project.
http://youtu.be/eKVmfTlKWbA
Old 02-09-2015, 10:26 PM
Supermario's Avatar
On going project you say?..... Tell me about it!
The latest is looking great! And your getting ahead of me on this one! Must have something to do with the fact you have no winter!
That's my story.
Old 02-10-2015, 07:33 PM
Originally Posted by Cooper View Post
Ha ha!! Looks good reg!!! Hope your feeling better buddy!!
Thanks RW. Feeling a little better today but not great. Perhaps some salt air tomorrow will fix me up!
That's my story.
I guess what I was trying to say is that this won't just be a conveyor when finished Shouldn't winter be the perfect excuse for you to be working on this stuff? It's not like you can do much outside... Anyway, I have a long list of other things I should have been working on but sometimes I need to get some stuff done of my own. Freshens up the brain and gets me feeling in the mood to work on stuff I have to let go of... Either that or I get mad and wish I was fishing instead!
Old 02-10-2015, 10:29 PM
Supermario's Avatar
Originally Posted by RCP57 View Post
Shouldn't winter be the perfect excuse for you to be working on this stuff? It's not like you can do much outside...:
So true and point taken! Game on buddy !
Old 02-20-2015, 11:42 PM
I made up the hopper yesterday afternoon. Today I got to give it a quick test. I use a cordless drill trigger when I'm bench testing things and I was using it here. I had it pinched under the weight of the conveyor but it got knocked around stopping the belt a couple of times. I think it will work OK though with some more effort. I was concerned that the speed would be too slow but it actually looks pretty good. If it were any faster I couldn't feed it quickly enough...
http://youtu.be/vUvI5S-ZL34
