Old 01-16-2015, 05:20 PM
Default Re: 4 Hour Bruder Dozer
I guess it depends on how much sand you are running in but I'm sure they will last a while. It's not like it's a really heavy model. You can always print more anyway right! I like the design! They look good. I need to get myself a printer that's for sure. What type do you have?
Old 01-16-2015, 05:26 PM
Ben1272 Ben1272 is offline
Ben1272 is on a distinguished road
I have a solidoodle4. It is not bad for the $599 price tag! I have mine adjusted pretty nice right now and get pretty decent prints now. It definitely takes a little bit to learn about the machine and what it can do and how to design parts given its limitations. The parts being ABS allow solvent bonding so larger more complex parts can be broken down into smaller more manageable parts and then bonded together. The sprocket I showed was printed from two parts, designed to be keyed together, and then solvent bonded.
I am going to make the entire drivetrain with this approach and will post pictures as I get further along.
I think I am also goinf to use the printer to make a fixture to hold the extrusion while I mill the sides clean and drill holes and mill slot.....we'll see how that idea pans out!
Old 01-16-2015, 05:44 PM
Mikem Mikem is offline
Today I was a the home despot to find the track pad material and the lady who looked for it for me found out it is a discountinued product . So I bought the remaining stock 3 pieces . Mike
Old 01-16-2015, 06:30 PM
Here is a shot of the printer making the sprocket I showed a couple of posts ago.
Old 01-16-2015, 08:28 PM
Sounds like I need to try and buy some more of that trim! and a printer.....
Old 01-26-2015, 08:52 AM
Plastic pushing leaves and crawling around...
https://www.youtube.com/watch?v=8_Uo...tJ-DusnO8Onw7A
https://www.youtube.com/watch?v=EykE...tJ-DusnO8Onw7A
