Or if you want a little longer than King hauler you can use a knight rails. IHB rails are very nice but are not drilled. They have the taper milled in the end . Good luck with the build and be sure to post some pics
Woodhog |
Thanks For all the help guys, it I use the king hauler frame can I put three axels under it? ,maybe two drives and one tag would be nice..like I said I'm new to this kind of build..so I don't know a lot about it yet. learn as I go..thanks for all the help and info..gary
![]() ![]() side view of my globe on king rails. Also using a different transmission. Might work but you will be cramped. knight or cascadia rails might work. either way you're drilling and tapping new holes for the cab mounts. 3mm bit and 3mm tap!
Rc's are like pringles. You can't have just one!! my YouTube is - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Subscribe!! My Facebook - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Stuff; 01-18-2015 at 11:43 AM. |
Well I got my king hauler frame rails today,, so now all I do is build globe liner like a king hauler and then drill holes for the cab mount? I hope that's what I need to do.. by the way, your truck looks great..i just hope mine looks half that good..thanks for all the help..gary
