Old 01-18-2015, 01:57 PM
djcrabtree's Avatar
djcrabtree djcrabtree is offline
djcrabtree is on a distinguished road
Default Re: 6wd help
Originally Posted by fhhhstix View Post
Remove your front spring mount from the stock location and move it to the upper two holes, the ones for the front mount and the servo mount.
Travis
Unfortunately this does not work for me. The mounts now interfer with the body siting level and the nose is still to high. Plus the upper holes for the servo mount and bumper mount are further apart than the original mounting holes for the suspension. Any more advice or a thread that goes into detail would be much appreciated.
Old 01-18-2015, 09:14 PM
As long as the holes are in the stock location as they are on stock rails they will fit perfect. I have done it many times as for the body you may have to to trim it a little to fit if it is a king hauler body.
Old 01-18-2015, 11:38 PM
djcrabtree's Avatar
That might be my problem then. I'm not using stock rails. I'll have another go at it tomorrow see what I can work out. Thanks for the pics that actually helps more than words.
