Old 01-22-2015, 02:38 PM
Rimrock Rimrock is offline
Default Re: Current alarm, for a motor
A slip clutch would been good, if I had room, put it's too compact
Old 01-22-2015, 04:28 PM
Supermario's Avatar
A buzzer or warning device is much more complex of a device compared to a circuit breaker. Using a breaker you also don't have to worry about not hearing the buzzer due to noise or other equipment around you?
It does get loud at RC shows with lots of trucks running around.
Not sure if they make small versions but on the 1:1 machines I work on, some are equipped with auto reset breakers. Those would be perfect for you.
Old 01-23-2015, 05:55 AM
You are correct I agree to that, it sure can be noisy when out in the 'field' and it could be difficult hearing the buzzer.
I guess a auto reset breaker will be the thing to go for), and forget about any alarm. I see now that my breaker must not be larger than 2 amps, and I managed to find some auto reset ones with this value, where they sell parts for scale trains. After being tripped, they need some time for cooling down to reset, I don't know how long.
http://www.microminiatures.co.uk/aca...-Breakers.html
