Old 01-31-2015, 09:43 PM
osikasculptor osikasculptor is offline
osikasculptor is on a distinguished road
Default Re: 4200xl Hydraulics slow?
You only need about half a tank full when operating. I would make sure
that 4th valve is moving via the radio. You should able to hear it move
with pump off via that black dial. Even if you use the mix later, if you screw that Allen nut on the black pressure relief valve and 4th servo is working, the dial on radio should speed up and slow down functions. (Mix off/ down position on right toggle switch for this scenario)
