They are cute lil' buggers aren't they!! I definitely don't have room for my dogs on the bench!!
![]() And he's not sprawled out, he usually takes the whole couch for himself!! So that's why the cats get time in the shop ![]() So I got started on milling the center grouser out, only have 80-90 more to do!!! The jig I made clamps them at the link area. I can mill about 3 before having to move the track. Only problem is they are not identical and some concave/convex slightly. But once sanded up a bit they will look made that way ![]() ![]()
On the bright side the hinge points are getting a good lube
Make peace or Die! 1st Bn 5th Marines |
Joe makes a good point. You'll have to make sure you clean them up real good before going back into the dirt. Otherwise the Sand and grit will cling and collect wearing things out faster than normal ?
Currently Active Users Viewing This Thread: 22 (0 members and 22 guests) | |
