Old 02-07-2015, 09:07 PM
Cooper's Avatar
Cooper Cooper is offline
Originally Posted by steamer View Post
Depending on how many channels your transmitter has, just throw another receiver back there in the trailer and plug into the channels you're not using on the tractor. You can link as many receivers to a transmitter as you want in parallel. If you want two dump boxes to go up together just plug the ESC into the same port on both receivers and they'll both work together! Also you'll have to get a BEC to power up the receiver back in the trailer unless you have an ESC for a screw drive or something else
Rob
Thanks rob, what I have in mind; drive truck with trailer loaded and park, (have to instal a servo for fifth wheel lock) unlock trailer- switch rx on radio, lower landing legs on trailer, switch rx to truck, pull away, switch back to trailer and lower gooseneck, remove equipment, raise gooseneck, hook back up and drive away. All from a nice lounge chair equipped with cup holder!! No wires to unhook, no connections to make. I'm not having lights (yet) so electrical between truck and trailer isn't issue. If in future I will make some sort of contact points to keep in said lounge chair lol!! As my wife listened to what I had in mind, staring at me with a blank stair after I explained ,,, only to reply with I am the poster child of sloth!!! Haha!!
