Old 02-18-2015, 03:03 AM
Themonty73 Themonty73 is offline
Themonty73 is on a distinguished road
Default Bruder Tractor conversion
Hi guys,
Please help i'm looking to convert a John Deere tractor to rc but havent a clue about which speed controller to use, this device cant be to big as nothing else will fit into the tractor, please help.
Thank you in advance
Old 02-22-2015, 04:05 PM
rc_farmer's Avatar
Master Builder
Default Re: Bruder Tractor conversion
Have you started the conversion at all. Bruder is rather small, so the castle creation 1/18 mini esc would work perfectly and it can be programmed for brushed motors.
Giving up is not an option!!!
Rob
Old 02-23-2015, 10:49 AM
Hi Rc farmer,
Yes i have started putting it together but not gone according to plan, i have a sabertooth esc but its to big to go any where, not sure what i can use as i'm very new to this but want to have a go.
Thank you
Old 03-06-2015, 06:37 PM
SonoranWraith's Avatar
It's a dry 115 degrees.
They are expensive since they are from Germany, but check out CTI Thor15. You can cram several of these in a Bruder conversion. You should read the German forums if you want to see a lot of tractor conversions.
