IHB Scale Models Custom machined parts |
This is how I work things with my wheels ,sold by the axle . When you order them I need to know how many axles including front . Front axle is assumed standard non-driven unless specified differently . Rear axles are assumed duel wheels unless specified differently . prices are for the base raw aluminum wheel assembly . WHEELS CONSIST OF 2 HUBS 4 WHEELS /REAR AXLE 2 WHEELS /FRONT AXLE .
hole options available now ![]() ![]() ![]() ![]() { I'm no longer offering NON polished wheels } All prices + shipping base: 1 rear axle - $64.00 polished 1 front axle - $40.00 in a stand alone set polished 1 front 1 rear axle polished - $98.00 1 front 2 rear axles polished - $172.00 Options : powder coating ( steel buds ) - $2.00/wheel (white) super single ( front or rear ) - P.O.R. driven front axle in super single or standard - no change rc4wd hub nuts ( all ) ( I prefer you supply them ) center mount super single - P.O.R. hub covers : stemco look alike baby moons more hole shapes available in future also 5 & 6 spoke daytons I'll have update pics soon (dead cam ![]() Steve
RIP FreddyGearDrive 2-12-59/12-19-11 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by ihbuilder; 02-14-2011 at 10:16 PM. |
Hi Steve what tire size?
Do you have 2-1/2 " tires also? I need only four tires and rims. Only two axles on my LTM 1030. TEXKEN(ken) |
Ken these are 1.7 Id . I can make what ever size you want
I have a lot more to come + up date my pics , they're terrible ![]()
i wanted some super singles to run on a peerless i built . i talked to you a while back makin sure im still on the list . they are for tamiya axles
![]() Just a note to all . Those that have ordered are on the list . I am currently booked till the end of March with another months worth building up . It will be this way until I get a CNC lathe.
can the super singles be wider and what tire could you use ,more like the 445 series super singles on late model trucks,trailers
as of now as far as I know we're stuck with the tamiya width I check into it I would like to get as wide and low profile on these for my lonestar build .
Pm sent on rims!!
DONNY EAST COAST MINI TRUCKERS |
just a Note to all . with the new production I have switched over to all 2mm (metric) bolts for lug bolts . most prvious are 2/56 (std) bolts
I have to give half the credit for these wheels to the guy who made the blanks for me . With out his help we all be still waiting , thank you Jeff @ JP machining
![]() ![]() on the front hubs , If you wish to put 2mm acorns on in the future , you screw the bolt in from the inside of the hub .
Steve are the lug covers still available? Like the acorns or the spiked one's?
Nick , I only have spikes right now . blunts in a few weeks some how
Hi Steve,
I am looking for super single, wide type rims for a rear axle, for a 4x4 scania I am going to build. The rear axle will only be running one rim each side with a wide tire on it, looking at some like a 10 hole aluminium type rim like you have pictured. Do you offer something like this? Cheers, Joshua |
look at the last pic posted in this thread of a tub dump . that's what they will look like from the rear . Side will look just like a regular rear wheel .
What about set of scale super singles drive wheels? I know no one actually makes the tire but isn't too hard to cut 2 tires to make one. The hard part would be the wheel itself.
Hi Steve,
Do you have any news about the availability of those wheels ? I've sent you PM and contact form about this. Thanks a lot ! Nicolas |
Yeah great news !
Look forward to ordering my brand new wheels ! Cheers Nick |
Currently Active Users Viewing This Thread: 37 (0 members and 37 guests) | |
