Euro Style Trucks and Trailers A place for the Euro style trucks single and twin axle trucks and trailers... |
Next challenge was to build to upper part of the hood.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() In addition I saw that the side plate was too short. I had to stretch it by 5mm. ![]() Next step was to add the side parts of the hood. ![]() ![]() ![]() Now I started the most hated part, sanding, sanding, sanding, sanding.... ![]() ![]() ![]() ![]() ![]() And that's the state after the first sanding... ![]() ![]() ![]() ![]() A small video (click me softly)...
Greetinx Peter To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
After a while I noticed, that the space between cabine and fifth wheel is too large...
Two possible solutions: - New frame 5cm shorter - Fill the space with something... I decided to follow the second solution... LONGLINER !!!!!!!! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Step two: The roof
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() This is the state not yet filled or sanded. Next step was the second side plate ![]() The actual state ![]() ![]() ![]() ![]()
Next step was to fill the gap between the cabine and the side plates.
![]() ![]() ![]() ![]() ![]() ![]() ![]() While they were drying, I started to make the air gaps in the hood... ![]() The position of the middle parts ![]() ![]() ![]() The first electric parts found their final position ![]() Actual state all parts in place ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Now I started to fill the parts.
![]() ![]() ![]() ![]() ![]() Today I started to build two boxes to place the electric parts while the rest is drying after the second filling and sanding job. ![]() ![]() ![]() OK, now you're up to date... Good night... ![]() ![]()
