Old 03-20-2015, 08:36 PM
Cooper's Avatar
Cooper Cooper is offline
Default Re: Vario Digger in Cat Yellow
Yes I have looked at that!! And it's very good. I really liked how you added the male/female pins for assembly. I imagine the holes were a tad bigger than pins? Do you mix glue? I just use abs pipe glue from hardware store. Has been easy and great. I even have some black glue. But that will not be around for too much longer as government is basically trying to outlaw abs pipe in home construction. It's just a less dense wall structure than PVC. Problem was drain lines would sag. But that was from not having hangers used properly not the pipe. Thanks for posting that build it looks killer. " have tires, need to build something" lol!!! If I recall the comment.
Old 03-20-2015, 08:50 PM
JDH429's Avatar
JDH429 JDH429 is offline
Haha, Ya that's right. Had the tires..I'll build something to put them on.
I've never used glue, only acetone and a small paint brush. Welds the parts together like nobody's business, just like styrene and Bondene. Try it since you'll be without the abs glue due to the lack of hangers used...
Jason
