Old 03-31-2015, 10:17 PM
Default Re: RCP Compound
Been plugging away at my new play area after work the last couple days and I finally got it to the point where I could try out the road. I used the KW to pack it down since it takes up the whole road and weighs nearly 50lbs.
Ghost driver?
https://www.youtube.com/watch?v=0k5x...tJ-DusnO8Onw7A
I need to install a stronger steering servo in the truck. It just doesn't have to power needed.
https://www.youtube.com/watch?v=4m2S...tJ-DusnO8Onw7A
I like this view.
https://www.youtube.com/watch?v=1PQx...tJ-DusnO8Onw7A
https://www.youtube.com/watch?v=GbBw...tJ-DusnO8Onw7A
Once it was packed down well the Hayes was able to make it's way back and forth nice and easy.
https://www.youtube.com/watch?v=SPFK...tJ-DusnO8Onw7A
https://www.youtube.com/watch?v=NNBC...tJ-DusnO8Onw7A
A few shots from before I started driving on it. I cut some small trees and jammed them in the ground to make it look a little more natural. I will add some more details later and my plan is to extend the road out into the bigger trees and create a network of stuff using the fine sifted stuff.
Thanks for looking!
