Old 04-05-2015, 08:06 PM
Krewmember's Avatar
Krewmember Krewmember is offline
Krewmember is on a distinguished road
Default Re: a little dx9 help
Originally Posted by bigford View Post
so I want to switch between my trucks all 3 are on
1) I scroll to system set up
2) click yes
3) model select
4) now here is where the problem is....
my dump truck and quad king both shoot into reverse once the rf signal
is lost. the peterbilt don't move at all. I have the throttle cut set to 0%
on the C switch 0ff 0n 0ff. all the trucks are set up the same viper 15 esc
rc4wd 65 turn motors
the two trucks will do this with the throttle cut off set to on or off
I cant have fly away trucks at cabin fever
HELP!!!!!!!
Hmm, maybe you could try programing the fail-safe to set the throttle to zero?
Shawn
Old 04-05-2015, 08:29 PM
Shawn
I agree set your fail safes and rebind. Also did you center the left stick? You can do it your self the manual shows you hoe to do it.
Travis
