Old 04-14-2015, 03:03 PM
Default Re: D10T Build
Very nice finish. Is it that nice straight from the printer?
Old 04-14-2015, 03:24 PM
JDH429's Avatar
JDH429 JDH429 is offline
What's its weight at now? Will it be all electric with linear actuators?
Using this Izzybilt dozer with twin Firgelli L12-30-100-12-S on the lift is working sweet! The blade lift is quick & powerful.
Joe, each side of the undercarriage is almost 2 lbs, So im estimating the total built weight should be near 12-15 lbs. A tad over what i figured scale weight to be, 9.1 lbs..If i figured correctly.
This will be an all electric build. Ive got a set of 100mm L16 Firgellis to use on the blade, and a handful of L12s for experimenting with.
No, theres a a bit of post print sanding and treatment to get it looking somewhat smooth like it is. Thanks
Jason
