Old 04-28-2015, 05:57 PM
gismow's Avatar
gismow gismow is offline
gismow is on a distinguished road
Default Re: Custom build Scania Hauler T580
After some time of building with styrene and brass I'd like to change to the electrics again.
I started to build a new board to give the truck a more realistic behaviour. The main features are:
- Realistic speed up and engine brake behaviour
- Realistic brake behaviour with an emergency brake
- Realistic steer behaviour depending on the speed
- Slow steering if the truck is stopped
- Automatic cruise control feature
- Heavy load - The speed and brake is more slow in the same way as it happens with a heavy load on the trailer
- Gear mode (forward, neutral, backward)
- If gear mode changes, the truck stops automatically in a realistic way
- Providing a brake light and a reversing light
- steering up to 4 steered axle in correct propotional behaviour
After that I went back to the back lights, they got their LEDs.
The center board for the back lights
The center board to spread the lights for front and back
Greetinx
Peter
Old 04-28-2015, 06:01 PM
gismow's Avatar
Now it was the time to start painting
Greetinx
Peter
Old 04-28-2015, 06:05 PM
gismow's Avatar
Painting the seats I tested a new mechanism by using flour to give them a bit of structure.
Some last peaces are drying at the moment. Tomorrow I can pickup the frame, it's actually at the painter to be powder painted.
Keep you updated.
Greetinx
Peter
Old 04-30-2015, 07:43 PM
gismow's Avatar
The front bumper resp. grill is added
Greetinx
Peter
Old 05-04-2015, 03:14 PM
gismow's Avatar
Hi...
It's nearly done...
Greetinx
Peter
Old 05-04-2015, 08:39 PM
Rakthi's Avatar
Rakthi Rakthi is offline
Hi Peter, absolutely brilliant job! Followed the build on modelltruck.net too. Hat off to your skills!
Cheers!
Stephan
Old 05-19-2015, 03:13 PM
gismow's Avatar
Hi...
Because of technical reasons I couldn't use standard IR technics to lighten the trailer. So I started to create an own solution with Arduino boards.
The sender board
The receiver board
The sender board placed in the truck
And here's a video of the first ride in the living room.
First ride
Greetinx
Peter
Old 05-20-2015, 08:38 AM
Serviceguyuk Serviceguyuk is offline
Location: Mostly a little world of my own but otherwise in the Bolton area in the North West of England
Serviceguyuk is on a distinguished road
Exquisite work.
Your attention to the smallest detail is a credit to you
I wish I had your patience
Old 05-25-2015, 12:04 PM
Louisbaby Louisbaby is offline
Louisbaby is on a distinguished road
Amazing build. I'm attempting one myself, so I might use some of your ideas to help me along. I have a question regarding how your cab is mounted. I assume the hood/bonnet hinges forward. But does the cabin remain behind? Or is that hinged too? I also want to build the long cabin, to house my smoke system and various other electronics, But I'm still stuck with how to access it.
