well after messing with the cylinders I found them leaking under load
where the end cap screws into the body. I tried to seal them with pipe tape and tightening them up but they still leak. new cylinder time the valve body im still not sure about |
Do you have the new cylinders? I have the new ones and have found them to leak as well. I going to HDepot and get some sealant and and maybe some new O-rings. If you tighten the caps, you will also find that the inlets are not centered either....
