Old 05-12-2015, 09:59 AM
Default Re: Hoarder Special!
Thanks. The roof was/is a little tricky and I'm not sure I have enough "dome" in it but it will do. I don't know who did the trans for sure(Heavy Duty maybe) as I got it in a trade. It has the motor swapped on backwards with a small reduction added using a jack-shaft. After some careful filing of the mounts it runs smooth and has reasonable speed using a 55 turn motor. It would be nice if it were slower but it seems to run about the same speed as my KH using a stock trans and 85 turn motor only it has a lot of power. The KH with 85T is horribly gutless.
Reg
