Old 05-15-2015, 04:42 AM
Rakthi's Avatar
Rakthi Rakthi is offline
Originally Posted by Rakthi View Post
Some extra nuts and bolts included, however the ones in the red box are on the parts list, but do not appear on the assembly list ??? Odd.
Well, turns out not odd at all ... those screws are for a different model truck.
Now bolting on the last parts to the frame to get into "paint ready" mode.
These are the parts from the locking/swivel mechanism that will hold the cabin to the frame. I will picture them in the order they went on. The locations on the frame is self evident due to the placing of the holes. Just very confusing as all parts have different sizes of bolts.
Here M2x4
Here M2x5
M2x6 and M2x10
The longer screw will hold a spring of the swivel mechanism of the cabin.
This part will hold the front bumper. M2x8
One side done, other is mirror image.
The last part is the cross connector. (M2x6 on the left and M2x5 on the right)
The bolts on this picture are M2x8 to give you an idea of the detail of the parts. The little hook will hold the spring of the locking mechanism
All in all not too difficult to assemble, but gave me some eyestrain figuring out what goes where. Too much information in the technical drawings.
Now we wait for decent weather so I can paint, or I just skip the painting all together, too worried I mess it up. Will see. Meanwhile I look and see what other things can be done.
Cheers!
Stephan
Old 05-16-2015, 11:40 PM
Rakthi's Avatar
Realised I also need to paint the air tanks. So did a quick assembly on that small unit. Good thing too, because doing so pointed out an error I made in the previous post.
Here a pic of the unit;
Screws are M2x4 and M2x8 and M2 nuts. One extra of each fastener.
The little stainless spacer is to make up for the stainless holder to which the fender support is attached.
And here the error I made before. I bolted the fender support to the wrong side of the stainless holder! Aluminum piece supposed to go in front, not behind!
Corrected ... And now easy to see why the little spacer is needed.
And this is how the air tanks will attach later on.
Side note - on the front support for the cab are 2 pieces. The left side on has an attachment for the steering linkage, the right side one doesn't.
That's it for now.
Cheers - Stephan
Old 05-17-2015, 07:58 PM
ricm ricm is offline
thanks for taking the time to put up this build thread....really interesting to see, I now understand why Tamiya is just $ but ScaleArt is $$$$$
wierd that you have to cut off all the bolts to get them down to the right length...
Old 05-18-2015, 05:21 AM
Rakthi's Avatar
Hi Ricm, glad you like it. Once I got the frame painted we will get to the more interesting bits that might be a tad challenging for me.
Indeed you get value for the money (at least I feel so) and the customer service at ScaleArt is top too.
The screws that need shortening ... someone on the German forum brought up the following: ScaleArt has 5 different truck lines, in different lengths and number of axles. Then the MAN alone has 5 different cabs too .. so somewhere this becomes a logistic problem keeping in mind that each truck is about three- to five thousand parts (fasteners included). So they try to streamline as much as possible and you see the same bits show up in the different trucks. Now if they would have to supply the right size bolts with each frame ... would just add a tremendously amount of work to their supply chain.
Also having the 1.6M bolts this length makes is easier to get them into the holes in the frame, and breaking them off is easy enough. Having to sort out the different sizes of nuts and bolts in the more complicated assembly units is already head ache inducing.
The further along I get with this kit, the more respect I have for the guys at ScaleArt who put it all together. On top of that, seeing what some of the members here build from scratch ...
Old 05-19-2015, 12:35 AM
Rakthi's Avatar
This morning, clear sky, sun ... so decided to give the painting a shot.
Hung the bits up on a nylon string in the sun to warm up the metal. Paint I used is a local brand of high temperature paint. Only one I could find that was not gloss. Bit hard to see all the small bits with the plants in the background. (The fencing looks the way it does because it is meant to keep our cats in)
Could have done better, but all in all very pleased with the result. Being black it will be easy to touch up later. I also remembered to do the hydraulic cylinders at the last moment.
Glad that this part is out of the way.
Cheers!
Stephan
Old 05-21-2015, 05:58 AM
Rakthi's Avatar
Today I bolted on the Rockinger Trailer Coupling. Easy I thought ... only took about 2 hours. (got a bit carried away with pictures here too)
Because there was only €26 (without tax) difference between the manual and the remote controlled one, I decided to go for the radio controlled one.
What is in the red square is the manual version, the rest is with the radio controlled one.
This coupling is truly a masterpiece. Here some pictures
Left side
Right side - closed
Right side - open (closes automatically when the tongue of the trailer hits the back part - manually with the little lever at the bottom)
Here a link to a short movie I found on YouTube that shows this:
https://www.youtube.com/watch?v=YyJbYVeywP0
Bottom - the spring allows movement to the left and right (no movement when coupling is open)
Top
Front
Back
So unpacked the lot and all I really needed was the 2 black bits with the arrow pointing to it, the cable and the servo. The rest are for every possible truck ScaleART produces. So lots of spare screws, washers etc.
To get the little black lever on, one needs to remove the big stainless one.
This was not as easy as it sounds, but a bit of scrap rubber to protect the polished metal and pliers took care of it.
The black lever pressed in place (used a box driver) on the square protrusion. Looks like a grub screw is needed to hold the cable in place.
Found in the bag with fasteners.
Next the servo support goes in the back cross member of the frame
The holes in the trailer coupling have thread in them. Elected not to drill it out. So first screw in the 4 screws.
Then loosen each screw in turn and offer up the M2 nut with tweezers (no other way to get to that area)
Then screw the screw back in whilst holding the nut with the tweezers, and tighten nut with 3mm spanner. Loctite applied.
Next up, prepping the servo and servo horn. Temporary attach the cable. I cut the rubber supports in half and filed off a couple of mm of the copper bushings that go in the rubber. I felt that otherwise the servo might sit too high. Can always change this again at a later date.
Servo bolted in place and cable trimmed to right size. A blob a glue added to where I cut the cable to prevent fraying. The servo horn is just loosely attached for the moment. I still need to centre the servo.
Cheers!
Stephan
Old 05-22-2015, 04:07 AM
Rakthi's Avatar
Next up is the installation of the hydraulic lift arm.
Here an overview of most of the parts needed for this set - just finding all the bits and pieces was a job in itself
First we prep the hydraulic cylinder
The nipples are screwed on, and although the manual does not ask for it, I added some thread sealant. Better safe than sorry.
Then temporary mount the cylinder to the hydraulic valve box. Temporary so we can determine the length of the hydraulic hose we need. Would be a real "joy" to have to install this after everything is bolted up.
Installed. I put the longer pin in the picture because the short one is the wrong one.
Mounted the valve body in the box to check length hose.
The hoses for this cylinder will attach to the area pointed out with the arrows. The 2 circled holes are the in and return line for the oil. There's been a small error in packing and the 4 mm nipples were omitted. ScaleART already informed me they will ship them ASAP .. still will probably take 4 weeks to get here.
Hose length determined and cut to size, attached it to the nipple. First slide on the hose and then press the sleeve home.
Next is the connecting rod. (it mounts the other way around from how shown)
Then the actual kicker, that will have to slide over the rod when we install it in its proper position. (The kicker has to be horizontal when cylinder is completely out.)
Then slide the assembly into the frame through the holes provided in the sub frame. (had to ream out the holes a bit due to the paint that got in)
The valve box needs to be attached with 4 M2x5 screws to the box holders on the frame ... one of them is a absolute pain due to no room at all.
Here all installed (including above nut and screw) seen from the left. I also installed the 2 rubber bumpers.
Here from the left. Rod that holds the kicker is secured with an M3.
Last part was bolting the diamond plate cover to the valve box cover.
That's it for now. Cheers!
Stephan
Tags
8x8, arocs, scaleart
