Jared,
As a newbie machinist I have to ask. How or why did you decide to make the side frames from a single chunk of aluminum instead of starting with to pieces of bar stock and then bolting them together with spacers? It looks like a lot of milling to remove all that material in the middle? I have the same question about the center part? I was going to try an make the center from a 1/4" plate and then add "side skirts" to make the upside down box. I made some of the sides using channel, but I think I'm going to redo them using two part of bar stock and spacers and then I can do rollers as you did. Thanks again for the thread! I refer to it as I am working on mine. Jim |
Jim, the main reason I did it this way is because I have a mill and I wanted to play with it
![]() Actually, milling out the center was the easiest part. The outsides took the longest. |
Jared,
Thanks, that all makes sense to me now! Jim |
