Old 05-21-2015, 06:41 AM
cosworth34677's Avatar
Default Re: made a tank and smal problem?
Originally Posted by Serviceguyuk View Post
It may be as simple as a little over filling.
Oil does heat up in any hydraulic system and will expand as your pump works.
Try draining or syphoning a little oil out and then run it.
Just trying help
Originally Posted by thebigo View Post
Did you vent your tank? Install a small vent tube somewhere behind your tank.
i took out a Little oil. helped alot but still dose it.
how do you keep the oil from coming out the vent?
Old 05-21-2015, 05:49 PM
chris deacon's Avatar
chris deacon chris deacon is offline
chris deacon is on a distinguished road
Fit a long pipe on it and keep it higher than the tank?
Old 05-22-2015, 03:58 AM
Serviceguyuk Serviceguyuk is offline
Location: Mostly a little world of my own but otherwise in the Bolton area in the North West of England
Serviceguyuk is on a distinguished road
i took out a Little oil. helped a lot but still dose it.
Chris is right, just run a pipe higher than the tank top. If you are worried about leakage you can get a filter/breather end fitting but always keep that upright and higher than the tank top. Gusto make small fittings and I'm sure they make a 3 or 4mm glass/ceramic breather end fitting that will simply push into the end of your overflow pipe.
Bets of luck
Just trying to help
Old 05-22-2015, 04:21 AM
I ran out time to edit my post but as an alternative you can use a small engine fuel tank filter like this one probably available from anywhere.
http://www.aliexpress.com/item/Small...234031721.html
Just trying to help
Old 05-22-2015, 12:03 PM
Joe25's Avatar
Joe25 Joe25 is offline
Joe25 is on a distinguished road
Could you post a link?
Make peace or Die! 1st Bn 5th Marines
