Just hauling dirt, shouldn't be a problem... maybe a strip of duct tape to cover.
![]() Managed to do a bit of hauling this evening, works awesome! ![]() 6 scoops on the trk & 3 1/2 on the pup, moved a lot of dirt in an hour... darn the luck the B50 doesn't fit through opening between house & lean-to. ![]() ![]()
I'm sure you checked and double checked Joe but are you sure if the oil tank wasn't there you can approach at the proper angle and squeeze through?
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests) | |
