I'll post some pics of it tomorrow. Once it's in the truck it is barely visible. Not as impressive as the one on your Jeep though. Ready assembled and greased too, just like the axles.
Think I take a break for a couple of days, back hurting from hovering over the model trying to get a handle on those nuts and bolts. And actually should finish varnishing the front door ... for some reason I haven't have found the time for that ![]() Stephan |
Hi Prop, here the promised pictures. It's a 3 gear box and a transfer case. In normal operation, the power of the motor will go only to the rear wheels, when you lock the transfer case you are in 8x8.
Nicely detailed and beautifully fitted. Once installed you can only see it when you turn the truck on it's back. The electrical motor is a brushed one. It's a Faulhaber 2657, 46Watt one. Screws into the gearbox and immobilised with a grub screw. The transfer case threw me a bit, it gets placed in the middle, so the input and output size go towards the front. The position of the locking bit was confusing until I realised you are supposed to run the cable through the provided hole (you can see it on the left in the 2nd picture) and then with a 180° turn towards the front of the frame. (I guess this is also why this is the only one where the bowden cable has a teflon insert. ![]() ![]() ![]() ![]() ![]() ![]() ![]() Propshafts. Top one is from motor to transfer case 2nd one is between 2 front axles 3rd and 4th one is either between the rear axles or from rear axle to transfer. (can only see once transfer case is installed) Last one is from transfer case to the front axles. ![]() ![]() |
Got around to assemble the rear part of the roll on roll off mechanism.
Here all the bits and pieces in the approximate place of assembly. ![]() First the main frame assembled ![]() Then the sliding and fixed hook that hold the container in place. ![]() Ran into a problem with the right one. The frame is milled to create a channel in which the mechanism can slide back and forth. I guess the bit used in the milling was a bit worn or damaged and the machined surface was rough. Tried to flatten it with a small flat file. It worked up to a point. ![]() Then I realised that it was the screwheads that were getting caught in the rough area. So too the file to them and problem solved. At one point I used the dremel and accidentally filed a bit of the actual piece too. No biggie as it is not visible. ![]() Have to pay attention here too. The bar attached to the sliding hook with those 2 screws connects to the other parts of the mechanism with a countersunk screw. So have to make sure it is installed the right side up. I succeeded in having both sides wrong. ![]() Next the rods of the mechanism. They are 64 mm long as per the manual. They are attached to the above rod through a bushing that goes into a sleeve through the frame. ![]() Here is one rod inserted. The second one is at this moment in the oven for 5 - 10 minutes at 180°C. One of the 4 balljoints of this package had a 3M thread. Didn't fit on the 2M thread rod. Easiest solution, some 2K End Fest glue and better than ever. ![]() While the pushrod was cooling off, installed the axle and the wheels on which the containers will ride. Axle immobilised with cir clips ... smallest I've ever seen. Absolute nightmare to get on because I didn't have the right tool and had to use 2 needle nose pliers to open them up. ![]() I was too fast installing the rollers ... they had to come off so I could attach the cover plate and the guide for the hydraulic line. ![]() Finished view from top ![]() and bottom ![]() Cheers Stephan |
Tags |
8x8, arocs, scaleart |
Currently Active Users Viewing This Thread: 9 (0 members and 9 guests) | |
