Old 05-31-2015, 11:16 PM
Default Re: Dragline Crawler Build
Ehow instructions for circular pitch...
Instructions
1
Measure the gear's diameter. For this example, imagine a diameter of 6 inches.
2
Multiply this answer by the constant pi, which is approximately 3.142: 6 × 3.142 = 18.852.
3
Divide this answer by the number of teeth around the gear. For example, if the gear has 28 teeth: 18.852 ÷ 28 = 0.673. This is the gear's circular pitch, measured in inches.
Read more : http://www.ehow.com/how_8660734_calc...lar-pitch.html
You might start by wrapping the hub with the track and counting how many cogs you need.
Old 06-01-2015, 06:45 AM
Rvjimd's Avatar
Rvjimd Rvjimd is offline
Ah, I knew there must be a formula for this. I am just now reading your post, so I will apply the formula to my current parts and see how it compares and then adjust and make a new part.
I don't really want to make the tumbler any larger, so this information should help a great deal!
Thanks,
Jim
