had some time for testing today due to bad weather.
need to swap out the tipper motor for a faster one, it lifts the load easily but too slow. https://youtu.be/43fAmasc1OU |
well , its almost winter here in New Zealand and the outside digging is not so much fun, so another project I have wanted to build has been started.
A rock crusher. I have made the crusher box out of 6mm steel and used a 10mm round bar drilled off set to make a cam, made a crusher plate and tested. hooked up a battery drill and crushes a beer bottle cap no worries. heavy duty springs at the bottom of the crushing plate give me a little movement and a bit of adjustment. It will have its own tracked drive system but will have a generator ( battery box ) to power the two conveyors and the crusher motor. I may need to use bigger flywheels but that will be an easy change. Once all functioning I will fire up the 3d printer and give it some detail, but the main concern will be function. I will also make some new crushing plates out of stainless steel which should last longer. Heres todays progress. ![]() ![]() ![]() ![]() cheers andy ![]() |
