Old 06-09-2015, 10:49 AM
Exclusive RC Exclusive RC is offline
Exclusive RC is an unknown quantity at this point
Default Re: CAT 5080 Front Shovel
if anybody can do it in plastic its you brian!!!
tl
Thanks bud
Originally Posted by Wiskybilt View Post
I like the way these dig from grade up. Digging a roadway or face cut out of the bank seems like a better setup than a regular excavater.
I agree
Originally Posted by modelman View Post
I'm no fan of the plastic stuff but I like the machine you have chosen. I prefer the older style shovels but any type of shovel I like and will watch.
Thank you, and yes the plastic isnt ideal but I believe it will work out just fine.
Originally Posted by cosworth34677 View Post
nice
Thanks
Fumotec incorporates 3D printed parts in his models, like the quick coupler on his hoe, seems to be holding up fine.
Other than the lack of weight, I think 3D model will prove to be quite robust.
Will you Brian be building the u/c from steel?
Thanks Joe, and im debating on steel or aluminum for now, butost likely steel tray and everything else printed, i will be printing traxk pads and other wear and tear items with metal filament. Counter weight will be hollow and filled with brass or lead.
depending on the size of this machine i would buy
the undercarrage from rcbmin . i think they have both rc4wd and
the kat carriages
I want to build everything myself, and what they have is too small, this rig scalled is about 12 inches wide and tracks about 18" long tip to tip
