been trying out windows movie maker, just a mess around of rc stuff in slow motion.
https://youtu.be/lKefR_tvNww |
hey Justin heres a real quick video of the crusher crushing dirt lumps.
just fitted battery drill to shaft and had it set on low 0- 400 rpm, it appears to work better at the higher speed but needs conveyors running to take away the crushed dirt as it blocks up with out them running. the crusher motor is a 1200 rpm unit so I can slow it down on the pot on my power supply box. http://youtu.be/TE4-31RpFto cheers andy |
heres test #2 , big rock ( hard dirt) may have to change crusher plate to make gap smaller at bottom but first I need my conveyors running so it has a chance to break the lumps.
I think the problem is that the dirt is pilling up on conveyor and dirt isn't going far enough into jaws to be broken down. I think once the conveyors are running and there is weight ( more dirt) on top of the rocks in the jaws they will be forced down the shute to be crushed. heres a quick video , let me know if my theory is right? cheers andy http://youtu.be/Oce8bhDK7gE |
Your right Andy. The more in the chute the better. Crushers are hungry and need a steady flow of material otherwise single chunks will skip and dance around. That's cool if you can easily adjust jaw distance and crush different grades or size of material.
