Hello,
So in the past I was going to make this dragline RC cause I have a ton of speed controllers, motors, servos, ect... But there was two big reasons that made me push away from the idea. 1) battery supply, to do what I need to do I'm going to have to run acoiple good size lipos and always worrying about charging them. 2) controls, I do not have the know how to take apart these controls and build my own controls out of them ( as I have to have joystick type controls for realism as I am currently working toward dragline oiler trainning) Now I've seen builds and a lot people seem to be running these off a 110v power source, so I came up with the idea of maybe using a power supply of 110v and decreasing it to a 12v for the motors and such. ( this would be my switch shack) from there I would run my power to controls and to my dragline. That way the dragline has a power cable like real life and no worry about battery's. Now the question is, where can I get a 4 position momentary switch type joy stick that won't kill the bank that I can wire to this dragline? If you have any thoughts on power supplies, wiring or any input I'm all ears on doing it a better way! Here are the "joy stick " type controls I have found so far the best thing in my mind, but idk about the voltage and amps ect.. http://www.amazon.com/Position-Momen.../dp/B009IUMG78 http://www.amazon.com/gp/aw/d/B009IM...PBYDRSRKDFTPMY |
What scale are you building in? Its gonna be awsomely huge!
The scale I haven't worked out just yet. When i started building this dragline i looked all over the internet for the 8750 specs for all the measurement to go off, but all the webpages I had problems loading. Was browsing the other day and found all the info i needed.....
Those joystick you posted look really nice in position, they are little more pricey but whatever works I guess. Last edited by TylerDSAudi; 07-02-2015 at 01:15 PM. |
You said you work at a mine as an oiler. You should be able to get all the dimensions you need from your company's engineering or maintenance dept. IF THEY WILL LET YOU. maybe you can say it's advertising to the company.
![]() I see the joysticks Tom linked. Like I said earlier; I don't know much about this stuff. I do know there is lots more available these days than when I started out. Maybe this stuff is heavy duty enough to handle a large duty cycle. Depending on how big you're machine will be, remember it's going to have to work very hard handling a bucket full of dirt swinging 10feet way. Thats the case for me. Each bucket weighs about 12-15lbs and with my overkill in my electrics, there is never any overheating whatsoever. |
Yeah, I just need a lot of help on the electronics end. I do know anything on these subjects of all these haha. I do want to make it as simple as I can. AS little stuff i need to make it all work, that makes less go wrong in my mind. |
This sounds like a good approach to the project. I think you indicated something between toy and scale model? I like to try and keep stuff simple when I can and if it doesn't over complicate things I do stuff so it looks "sort of scale". I think there are some projects that stall during construction because of over optimistic ideas at the start. I know this from experience and even my current crawler project which I don't claim to be very scale or detailed is just complicated enough to make me groan and nearly give up at least once a day!
![]() So, keep at it, I like it already! I have all kinds of MDF, never thought of making something that big and using MDF for part of the project. Take lots of pictures and keep em coming! Jim |
![]() MDF is my favourite wood to work with for things like this, as you can shape it how ever you want! Great wood to do things like this and the house so far isn't too bad for weight either! |
