Old 07-02-2015, 01:34 PM
TylerDSAudi TylerDSAudi is offline
TylerDSAudi is on a distinguished road
Default Re: Progress Thread - 8750 Marion Dragline
Originally Posted by 9W Monighan View Post
You said you work at a mine as an oiler. You should be able to get all the dimensions you need from your company's engineering or maintenance dept. IF THEY WILL LET YOU. maybe you can say it's advertising to the company.
I see the joysticks Tom linked. Like I said earlier; I don't know much about this stuff. I do know there is lots more available these days than when I started out. Maybe this stuff is heavy duty enough to handle a large duty cycle. Depending on how big you're machine will be, remember it's going to have to work very hard handling a bucket full of dirt swinging 10feet way. Thats the case for me. Each bucket weighs about 12-15lbs and with my overkill in my electrics, there is never any overheating whatsoever.
Yeah i wish it was that easy, I would have had to go through all the lawyers first, then civil departments ect... I have them looking into me using the colours, name and they want their company on it if i do, which I am totally fine with. One of my fav draglines of all time!
Yeah, I just need a lot of help on the electronics end. I do know anything on these subjects of all these haha. I do want to make it as simple as I can. AS little stuff i need to make it all work, that makes less go wrong in my mind.
Old 07-02-2015, 07:31 PM
Rvjimd's Avatar
Rvjimd Rvjimd is offline
This sounds like a good approach to the project. I think you indicated something between toy and scale model? I like to try and keep stuff simple when I can and if it doesn't over complicate things I do stuff so it looks "sort of scale". I think there are some projects that stall during construction because of over optimistic ideas at the start. I know this from experience and even my current crawler project which I don't claim to be very scale or detailed is just complicated enough to make me groan and nearly give up at least once a day!
So, keep at it, I like it already! I have all kinds of MDF, never thought of making something that big and using MDF for part of the project.
Take lots of pictures and keep em coming!
Jim
Old 07-02-2015, 07:36 PM
Jim
Thank you! Yeah mine has done that to me I'm always over thinking everything and changing designs and how I want to do steps in the build, but that's why we do this cause we're crazy people . I'm building this as a working model and toy to play with. Once it works how I want it, then I can start adding detail for the model scale side like railings, vents ect..
MDF is my favourite wood to work with for things like this, as you can shape it how ever you want! Great wood to do things like this and the house so far isn't too bad for weight either!
