Old 07-04-2015, 11:35 AM
modelman modelman is offline
Default Re: Progress Thread - 8750 Marion Dragline
TYLERDSAudi-why don't you try to reduce the size of your pictures. I don't think there is a link for the pulleys you need. Those you will have to make or have made. If you are looking to build cheap, this may not be the best project for you. Even modeling is very expensive these days. Some of your parts will have to be custom made-($$$$). Motors and electronics-($$$$)-I wish you luck-maybe it can be done.
Old 07-04-2015, 04:37 PM
TylerDSAudi TylerDSAudi is offline
TylerDSAudi is on a distinguished road
That is the size that they get uploaded up as, I tried to downsize them with no luck. There's a difference in building cheap and building cheap with no money. One of my talents in sourcing stuff from big names to the little guys, with half the price and sometimes better quality. The pulleys have had no luck in finding as the closet thing I have found with a grove in the middle for the rope is tank wheels, but very slim pickings at best. I have found a set of plastic wheels that I'm using for mock up, but over time I would like to replace them with metal sets. I'm hoping to mostly be able to buy everything I need to speed up the build and if I can't buy it then I will make it over time.
Old 07-04-2015, 04:50 PM
SonoranWraith's Avatar
It's a dry 115 degrees.
You can have photobucket resize your pics when you upload them. Are you going make a jig?
Old 07-04-2015, 06:33 PM
Ok I'll try again cause I use photobucket. A jig for what?
Old 07-04-2015, 07:18 PM
Great start to the build! I don't think there is anything wrong with the size of your pictures. They are just not being spaced apart. Load each one as if it were it's own paragraph if that makes any sense and it will be fine. The same thing happened to me when I first started posting pics here from photobucket and Joe fixed it up for me by separating them.
Old 07-05-2015, 09:35 AM
Why thank you! It's a good start I'm happy with. I'll try to space them out
