Now have to do the back ledge of the interior.
For this we first need to attach the circuit board for the wiring in the cabin. This will make it possible to remove the cabine with only one plug to disconnect. ![]() ![]() ![]() ![]() ![]() However ... connecting all those cables with the board attached will be a pain. So removed it for the duration. It can be attached again later. ![]() The backboard goes in through the doors and I was surprised how easy it slipped in place. Had expected worse. ![]() It screws in from the bottom. The hole in the plate is threaded. ![]() The manual specs M2x6 ... however this makes the screw poke into the cabin with a mm or 2. Replaced those screws with M2x4s left over for another group. Perfectly flush now. ![]() Noticed I had forgotten the seat bases. Supposed to be bolted on before installing the floor. Still easily done good access from below. ![]() ![]() Next up the seats and dashboard or maybe I do the cabling first ... (so not looking forward to that bit) Cheers Stephhan
No point postponing jobs you don't like ... since nothing much going on today, bit the bullet and messed with the electrics of the cabin.
Sod's luck of course ... the bleeding power cables of the SMX are ½ inch too short ... ![]() Inserted the LED for the indicators and attached them with a blob of hot glue. Kind of regret it, I made an error and when removing the glue, part of the paint came with it. (right side). Well one can't see it, and thinking of painting the underside of the fender black anyway like in real life, so no big loss. ![]() Globbed some liquid tape on the back of the circuit board. Not really needed, but better safe than sorry with electricals. ![]() Inserted the 2 plugs and the Function 4 cable of the SMX plug. Since the speaker stays in the cab, I could actually just have soldered the wires together instead of making this convoluted connection. ![]() ![]() Rummaged through the bits and pieces one accumulates and found a female JST (?) plug that fitted the power of the SMX Module. Came with one of my chargers, but never used it. Also fitted the Universal Bus thing to the circuit board. I could have run that one separately to the bus connectors in the lower level, but then one extra plug to undo. ![]() Bolt the circuit board in place, which went easier than I expected. ![]() And now to deal with the KingBus system. The wires need be coated in some solder to make them stiffer, and then you can push them in the round hole where they clip in. To release them put a thin screwdriver in the rectangular slot and push down. (I didn't know this) ![]() All good an well for the single or double cables, but the 4 positive ones ... so I soldered them together and filed them to a reasonably small pin. (sorry shoddy pic but you get the idea) I know there are probably connectors in which you put the cables etc etc ... Wish I knew how they were called and where to get them. ![]() All the cables inserted in the module ![]() Module glued to the side of the cabine with the provided double sided tape. ![]() And a view of the mess ... left all cables long enough so I can be redone if needed. Thinking of cutting some foam to hide it from sight. ![]() So all in all this little exercise kept me busy for 3 hours + ... and I don't know if it is correct until I sort out the rest of the electric. Cheers! Stephan
Tags |
8x8, arocs, scaleart |
