Go Back   RC Truck and Construction > RC Truck's Odds and Ends. > Static Conversions
Static Conversions This is the place for all your Bruder cab and trailer conversions.
Old 07-08-2015, 07:02 PM
Scalebowler Scalebowler is offline
Scalebowler is on a distinguished road
Default Re: Tonka Winnebago
Been working different hours at work for the past month it seems so I have not had much time to work on the camper until yesterday so here is an update. I got the lift blocks for the front suspension finished up and mounted and I also machined a few plates that will go where the differential mounts to the leaf springs since I did not like the idea of having the bolts directly contacting the plastic differential case. Next steps are make a few shock mounts, servo mounts and drill and tap the holes in the rear shock mount cross member. I also would like to try and find a pair of mirrors from one of the Tamiya semi trucks and get some mudflaps with the Winnebago W on them.
Front axle lift blocks
Milling out the plates for the rear axle
A finally level Winnebago
Old 11-24-2015, 06:30 PM
Last set of pictures reuploaded
Tags
camper, motorhome, tonka, winnebago
