Old 07-15-2015, 10:06 AM
modelman modelman is offline
Default Re: Dragline Crawler Build
Nice work jim-this is the pay-off for all that work. The operator does look a bit rusty but I'm sure this will work it's self out . How many channels are you running? You have a lot going on there.
Old 07-15-2015, 10:41 AM
Rvjimd's Avatar
Rvjimd Rvjimd is offline
Steve, ya a fair lead would be good. I was trying to dig wet packed sand the other day and my attach points on the drag rope at the bucket are too high and cause it to tip the aft end of the bucket up. I plan to make some new brackets so I can move the attach point up or down for different soil types. I haven't really tried to tune this setup since I got it running last fall. I have the airplane instrument panel ripped apart for an upgrade so it looks like I will be driving again this year. I should find a topper for the truck so I don't have to sleep on the ground this year don't think Jennifer is coming with me this year. Going to be a long drive doing it all myself
Tom, i thought i had the bucket a bit higher on a few swings. As soon as i sat down i knew it was going to be a crash fest.
I am running 6 channels. The stupid motor controller is fussy so I have to use a separate BEC for the radio and servos, and that means every one of the seven sockets on the RX has a plug in it! They put the pins so close on the RX that the plugs hardly fit.
Jim
Old 07-15-2015, 11:36 AM
Rvjimd's Avatar
I should have just copied this picture from your thread Jared!
Jig to make the roller axel shafts. I decided to do it just like you did with a flat on each end of the shaft and drill them and tap holes in the side rails.
Jim
Old 07-15-2015, 11:44 AM
Those drive chains fit very nicely under there.
