Old 07-21-2015, 07:32 AM
Rakthi's Avatar
Rakthi Rakthi is offline
Originally Posted by apfubar View Post
Well done!
On the charge port, I would suggest checking if you can get a right angle plug of the same size... Typically they are a bit shorter...
On the sound, I am sure you will get it sorted, more than likely it is something simple... Wrong plug or wrong direction etc... There are lots of wires in these things... It's really easy to get a couple wrong first time around! :-)
Let us know if you want us to review how it is connected... Pics and diagrams will make that relatively easy...
Cheers,
Ap
Hi Ap, not too worried about the SMX, as you say, probably have reversed a plug somewhere. In the next couple of days I will check up on the wiring in the cabine and take some pictures of how I plugged what in where. Maybe I'm too close to it to see where I might have gone wrong.
Good idea about the right angle plug for the charger! Meanwhile succeeded in charging battery by using some crocodile clips - bit iffy but went OK. Battery does get very hot though.
Ahhh...
Just looked at your jumpers on the SMX...
Check the manual, on the bottom of page 9... I think you have the smx in setup mode... If you haven't changed the jumpers since you took the photo... In post #108...
Cheers,
Ap
WOW, you went back to check .. thanks for that! ... The jumpers at the moment are per the manual in setting 1
When I tried to turn change the programming on the SMX, nothing much happened ... supposed to get the air brake sound, but nada ...
Thanks again for giving it some thought! Really appreciate that!
Stephan
Old 07-21-2015, 07:54 AM
Rakthi's Avatar
So this morning the non working servo controlling the valve of the hook arm was up for checking. Easier said than done, had to take all the wiring back apart ... Good thing I did remember to move the mechanism in the up position beforehand because you can't move it now that it is filled with oil. Luckily I could pull the wires without having to take off the bottom plate.
Had to pull wires of both servos because they both run through the same piece of shrink tubing.
Didn't see any breaks in my soldering but just to make sure added a new lead I got from the gear servo I busted. Put it on the tester and it worked. I figured one of het three wires must have an internal break. So sigh of relief. And then the struggle getting those wires back to the front. Took some convincing - and a bit of rope - but got it done.
As truck stands now. Hydraulics in working order, all lights on truck working (except cabin) etc etc - Looking at pictures I notice I still have to put up the protection rings on the front wheels.
Tomorrow I will check on the wiring to the Universal Kingbus in the cabin and then connect it directly to the 4 way connector and bypassing the flat cable. See if that sorts the problem.
And then ... I will start on the container ... been saving that one for last. A nice and simpel straightforward nuts and bolt job.
Tags
8x8, arocs, scaleart
