Old 07-21-2015, 09:07 PM
Default Re: wheelbase
Originally Posted by JAMMER View Post
I could be wrong but I think you measure a wheel base from the center of the front axle to the center of the rear most axle. Ed
Yes you're wrong.
Center of steer to center of tandems.
If it were tri drive? I'm not sure. But likely still center of rear two axles.
Old 07-21-2015, 09:49 PM
Bo Wallen's Avatar
I think it's confusing but it might help to look at this site, http://www.cdxetextbook.com/safetyIn...aswhlbase.html hope it helps.
Bo
Old 07-21-2015, 10:39 PM
Bo Wallen's Avatar
I like this explanation or what it's called....Wheelbase
Manufacturers advertise wheelbase according to the distance from the center hub of the steer axle, to the center-point between the two rear wheels on a three-axle truck. So, stick a ruler vertically in the ground right in between the two rear tires, and measure from there to the steer axle. However, possibly more relevantly, officials at the DOT take literally the simplistic technical definition of "wheelbase," which is "the distance between the front steering hub and the rear wheel hub." So, when it comes time to pay tickets for bridge length permit violations, wheelbase measures from the center of the last wheel. Otherwise, advertised wheelbase is from the center of the two wheels, or from the hub of the center axle on a four-axle truck.
