Old 08-20-2015, 09:20 AM
1985 kenworth's Avatar
Default Re: problen qith new flat bed trailer
Make sure when you tighten the u-bolts on the suspension that the leaf springs are straight ..they tend to shift when you tighten the u-bolts .after you tighten them you should hold them up and make sure they are straight.i had that problem with a tire rubbing and when i checked ..the leaf springs as i was tightening them shifted to one side so the axles went on crooked...hope this helps
dwayne
