Old 08-29-2015, 03:19 AM
uktwin uktwin is offline
uktwin is on a distinguished road
Default Re: hydro pump controller on excavator
Originally Posted by woodhog View Post
All mine are brushless systems 2 are leimbach and 1 is premacon (jung) . I mix all my functions on all the equipment so pump is only running when it needs to. I have a cheap brushless controller that I put on a leimbach pump and it works just as good as the german esc. so I would just use whatever is available close to you.
I want to convert my Leimbach 922 to a brushless pump but if my German is correct the Leimbach system is 2 speed and I just want to go with a simple brushless controller, much easier to mix the speed to every thing else, what motor did you use instead of the Leimbach set up or did you get the Leimbach motor and change the controller, many thanks, great forum by the way.
