Old 08-31-2015, 12:52 AM
chris1210's Avatar
chris1210 chris1210 is offline
chris1210 is on a distinguished road
Default Re: stretched scania with wedico tanker project
Originally Posted by bigdogrod View Post
see if you can pick out which tamiya parts are in there... lol
LoL, it's 4 air horns that you used to build the valves, I need two of those for my King Hauler
Old 08-31-2015, 07:58 AM
bigdogrod bigdogrod is offline
bigdogrod is on a distinguished road
you are correct sir
but you only get partial credit, there's 3 other stock tamiya parts in each valve assembly..
Old 08-31-2015, 06:42 PM
you are correct sir
Turn signals and air breather top mount.
Old 08-31-2015, 06:50 PM
very good, give the man a beer
but still 1 more part in there...
screws don't count
Old 02-19-2016, 11:10 AM
ok, found a way to get another cab, buy a whole truck.. lol, i think i need to take a bit more off. i measured the tamiya wheel and scaled the real pic to match, then measured from the cab door to the end, and cut. but these 2 comparison pics don't seem to match real well
Old 02-19-2016, 11:21 AM
cut about 3/4 inch off the cab, looks better now. i read that the builders added 51 inches to the original, so 1/14 of that is about 3.5 inches, and that's about where i'm at. i may have messed up using the blue tamiya cab, i thought it was pretty much just blue plastic, but it has a clear coat on it, so i sanded off as much as i could. especially where the glue will sit. i'll give it a gentle wash in brake fluid before bodywork.
