Old 09-10-2015, 10:11 AM
Digger_Bear Digger_Bear is offline
Digger_Bear is on a distinguished road
Default Re: Scania 8x8 dump
Quick update my friend fitted new tank and that leaks as well. He's since got the first tank welded up so hopefully that has fixed the problem.
Old 09-11-2015, 05:59 AM
chris1210's Avatar
chris1210 chris1210 is offline
chris1210 is on a distinguished road
After your friend replaced a new tank where is the leak located? You can test it by removing the breather and seal it with a 3mm screw then run the pump to see where the leak comes from. I guess the leak comes from the pump and not the tank.
