Something else, the PRV that's in these Chinese models, the coiled spring is much too stiff & with the barrel so short - not a lot room in the 1st place for a proper length coil to allow the BB to move to relieve pressure & allow flow. Throw that piece of crap away & make your own with a longer barrel for a lighter spring so you can get a much finer tuned pressure setting & that 4th valve wouldn't be needed.
The forth valve is similar in function to a CAT hyd system. Don’t change the speed of the motor or pump but adjust the flow going to the valves. Where it differs is the real machines do this with dual variable pumps and the model does it with a dump valve not exactly the same thing but still the same result. Replacing the junk motor would help a bunch I have found that it will lock up due to its poor tolerances and that alone makes it hard to start without a load. A gear reducted motor would be a big improvement the motor spins way faster than the pump can use so slow and more starting power would be a help. The vario uses a belt drive with a smaller cog on the motor and a bigger cog on the pump hence the gear reduction slow it down and utilize the power spent to operate the pump
a little racist I think.
Let's not be hyper critical and bring all the b.s. Politically correctness into this hobby, it is simply a reference to the whole world business machine, don't read a book about it, buy a cheep machine and also buy a high quality machine and educate yourself. There is a difference between cheep, inexpensive, low quality, high quality, and expensive. Economics 101- no such thing as a free lunch!!
Please delete if offensive, I just don't want to be politically correct and worry about hurting someone's feelings, that is too much like work and this hobby is as far away from that as I can get ![]()
regards Kevin. |
ok
I changed it... better? I have no personal resentment to the Chinese ppl or any other ethnicity on this planet.
China mentally in manufacturing on the other hand from my viewpoint, they're all about production & couldn't care less about quality, just get it out the door, sell it cheaper than anyone else can & sell lots!
Hi
I totally agree, for a couple of dollars more in the production costs and a little more time they could produce some hi quality stuff. but it's just that will do mentality and sod the quality that will always let things down. dave |
