Old 10-07-2015, 08:03 PM
Default Re: JBC limited NZ
I had the beier sound card sitting on desk for a while and I want to get the hydraulic fluid sound thing happening when the rams move and also a few more realistic sounds happening.
also, I stole the sound card out of the excavator for my KH dump truck build.
I need to spend a bit of time trying to work out how Im going to do it , but I have a plan...
just need to find the time.
cheers andy
Old 10-12-2015, 12:44 AM
while the wife is off having a good time on a girls trip over seas I have been tasked with getting the vege garden sorted...
Step up the excavator soon to be followed by the loader.
not sure how I will plant the produce in the ground but at least I've made a start.
a quick video so far
https://youtu.be/UR8AO0sguqI
Old 10-12-2015, 11:13 PM
made a few changes to the dozer, fitted some aluminium track runners to stop the tracks coming off.
not quite right as you can hear the pop rivets holding the track pads hitting the runners.
out with the grinder tomorrow.
heres a quick vege garden video
https://youtu.be/A6SouJ-90hE
Old 10-20-2015, 02:42 AM
summer is on its way, found a possible track to run the semis on.
problem is that it is at serious altitude, with a 6 - 10 foot drop [roll to the bottom] . which wouldn't be good for the trucks.
got the excavator in to make a start on the road but will need the dozer and a water cannon to clear most of the really hard dirt before I can start to make a driveable road .
just happen to have a Polaris ranger, a generator and water pump , so that part is going to be easy.
almost lost the excavator a couple of times but the camera must have stopped..... like my heart.
here's a short movie of what Im up against
https://youtu.be/5AehQHE-npM
Old 10-20-2015, 10:19 PM
jack van's Avatar
jack van jack van is offline
Smile Re: JBC limited NZ
cheers andy
hmmm i had a plan famous last words lol
Old 10-21-2015, 08:43 PM
yes a plan is always good, but sometimes it changes... LOL
plan changed a little , needed to make some room for the new esc,s
much bigger and complete with fans.
so hashed up something that will do the job.
heres the new 2mm engine cover
radiator cover
almost there
will print up some doors and handles to give it a little more detail once the paint has dried properly .
cheers andy
Old 10-22-2015, 10:40 PM
made a start on another project that has been sitting in the shed for a while now, the mighty KAT excavator.....
I know its lightly built and basically rubbish, but I think I can make it a little better than when it arrived.
The base was slightly bent and a little wobbly, just too lightly built.
a $80 purchase of a 3mm thick steel half sheet and the job begins
Im going to use the same set up as in the rc4wd excavator as I have all the parts already.
I have ordered 3 large ecs,s for the tracks and turntable , now its just a matter of making it all fit inside.
I used the original base plate as a template for the top half and reproduced all the other panels and welded them together to give it some more rigidity
wasn't happy with how the way the main boom rams were fitted , so added an extra mounting point to stop any possible twisting.
need to sort a few panel gaps , also instead of a counter weight at the back I may make a built in oil tank to save a bit of room for the electrics.
a new bucket and quick release is also in order as is rebuilding the track set up.
but first mission is to get it digging for the summer and the youngest will be happy.
basically I think I will be using the KAT as a template to build a whole new excavator.
Old 10-25-2015, 02:19 PM
So as it turns out the KAT is only good for a template..
made up a new set of booms out of 3mm sheet and welded them up.
I have predrilled the pivot points but will make up some brass bushes and stainless shafts.
This isn't turning out to be a ten minute job.
a little CAT code paint make it look better
add one new boom set up and a new steel bucket.
and the 4200's new look
cheers andy
Old 10-25-2015, 03:36 PM
Supermario's Avatar
Looking good Andy. Always nice to have a second digger. I really like the 4200 upgrades. The cat walks is a nice touch. Tracks look a little loose though?
Old 10-25-2015, 03:38 PM
Supermario's Avatar
I can't remember, do you have an interior in the 4200? And have you seen this? I just discovered a few days ago..
https://www.ttm-shop.de/katalog/arti...uer-ttm-bagger
